Fabricated Motorsports
Please login or register.
Login with username, password and session length
Advanced search
News:
Pages: 1 [2]
Author Topic: NIStune VS megasquirt  (Read 906 times)
StephenSheppard
  • Full Member
  • www.rotaryrelated.com
    • View Profile
    • Rotary Related
Re: NIStune VS megasquirt
« Reply #15 on: April 10, 2012, 09:55:48 AM »
Someone probably has the frequency of the idle air control valve if that's what your talking about. Troll the MS3efi forum instead of KA-t read stuff that doesn't even directly apply to your engine. You will learn a lot. You could also just use the jeep? I think it was idle air control valve that diyautotune sells with the adapter block thing. We did that on a celica supra and it worked fine. It sits external to the engine with a hose in front of the butterfly and one behind. Then we blocked the idle passage on the factory throttle body with epoxy so it wouldn't leak. It was on a 2JZ VVTI swap thing.
Logged
Wiring and electronics all day........
lilredrex
  • Newbie
    • View Profile
« Reply #16 on: April 15, 2012, 12:34:12 AM »
ok ill spend some more time on ms3efi trying to find information thanks for the direction
Logged
ak_slick
  • Newbie
    • View Profile
« Reply #17 on: May 01, 2012, 03:38:35 AM »
If it is a track only car you can easily cheat and just crack the throttle body stop or fab one since you won't car about the warm up or a slightly higher idle anyway.
Having Megasquirted my KA with a friend I can tell you that the IACV's on a KA are a pain. What are your exact goals for the MS ecu? Is this a daily or track only? Fuel only? Spark Timing? Coil on Plug? Just to run?
I'll help you as best I can from what I remember. :)
I can tell you that for the KA I found it easiest to pull off the intake manifold and remove the accessory valve and the idle air control valve to replace them with a GM stepper type, which I got running, but eventually just removed for a throttle stop. But this will depend on your car.
Logged
Pages: 1 [2]
