Here is the part I am sure you guys really want to see, The steering angle. We were able to achieve 61 degrees with a 17x9 +0 wrapped in a 245-40-17. The angle is insane. Everything posted here is included in our kits. We did however make a mistake on the mill with our stainless sleeve inner diameter for the FCAB. In a rush to have the car ready for the event in 6 hours, we remade a mild steel one at the last moment. Normally there is no modification to the arm, But since we were not able to head back to a mill, we had to modify the arm a little bit in a jam. You get the idea tho. These are exactly like the early 99 arms, just with a different inner ball joint.
Then we moved on to the little final touches. We added some sparco latches to hold the trunk and front bumper on, as well as a new flex-a-lite black magic 3500 cfm fan for our Level7TUNE radiator setup.
It all turned out very well. Definitely one of the lighter e36 turbo sedans? lol. Here is a picture of the scales before we corner balanced it and added a few lbs of ballast.
Alignment rack while practice is going on at the track lol.
MOD LISTS
Drivetrain
Motor
-Technica Motorsports built S52
-JE Pistons
-Stock Rods and Bolts
-ARP 2000 Head Studs
-Cometic .70 Head Gasket
Turbo System
-Precision 6262 Ball Bearing Billet Wheel Turbo. T3 .63 a/r exhaust housing
-Precision 46mm compact wastegate
-SPA Turbo Manifold
-Technica Motorsports Factory ECU Tuning
-Technica Motorsports Blow-Through MAF
-Technica Motorsports Injectors
-Technica Motorsports Oil Feed adaptor
-Walbro Fuel Pump
-S-Max Performance 22x12x3.5 mid mounted Intercooler
-Secret Services Auto custom 3 inch aluminum intercooler piping
-Secret Services Auto custom 3 inch aluminum Exhaust
-Secret Services Auto aluminum coolant expansion tank and coolant catch can
-NonStopTuning Alternator and Aux pulley system
-Toxic Fabrication oil catch can with -10an lines.
-Level7TUNE aluminum radiator
Chassis, Suspension, and Brakes
-Toxic Fabrication stitch welding and reinforcement.
-Toxic Fabrication roll cage
-BC Racing ER-Type Double Adjustable External Reservoir Coilover System
-UUC rear camber arms
-UUC rear trailing arm bushings
-VAC Engine Mounts
-Technica Motorsports chassis harness and fuse box
-Technica Motorsports rear subframe bushings
-Stock M3 brake calipers with brass guides and Technica Motorsports Stainless lines
-Level7TUNE Drift Spec Ebrake pads
-Brembo drilled and slotted rotors
-Secret Services Auto bash bar
Interior
-Sparco Circuit Pro Hans (Driver)
-Cobra Suzuka Pro Kevlar (Passenger)
-Safety Racing sfi belts. Purple and black
-Secret Services Auto ultra low seat brackets
-Level7TUNE Ebrake handle
-Circle track 14" aluminum steering wheel
-Speedway quick release and splined steering shaft
-Autometer water temp, K's 60mm boost, AEM UEGO wideband
-Technica Motorsports Modified dash
-Level7TUNE Battery Box
Exterior
-GM Plum Crazy Purple on every inch inside and out. (Sponsored by Nevrslo)
-OEM M3 sideskirts as well as front and rear bumpers.
-China Special r-iced out taillights
-Level7TUNE big BRO flares front and rear
-Nevrslo carbon roundels
-Long acre power cut off switch
-Sideways Vinyl
-Level7TUNE lexan windows
Steering, Rollers, Tires
-Level7TUNE SMAK (super mad angle kit)
-Level7TUNE steering knuckles
-Level7TUNE front lower control arms
-Level7TUNE delrin front control arm bushings
-Level7TUNE tie rods
-Enkei RPF1 17x9 +18 Front and 18x10.5 +15 rear (18mm adaptors all around)
-Nexen N9000 245-40-17 front and 275-35-18 rear
Id like to thank everyone who had hands in the build, Mike at Nexen Tires hooked me up with a truck load of their fresh tires, Bret and Jordan at Technica Motorsports built an awesome motor tuned like factory, Josh at Nevrslo supplied a clean shop to work on and a ballin paint job, Collin at ToxicFab.com designed and fabricated the cleanest e36 cage, Mike from NonStopTuning supplied the venue for my premiere and helped fund the build, The Right Step for their Texas drifting support, BC Racing Suspension for a set of killer dampers and awesome support, Aaron and Jimmy for getting their hands dirty, Ashley from Sideways Vinyl, as well as the Awesomeshop owners Mike Peters and Dereck Rodgers for helping out before Irwindale, Wade for helping put the final touches on my car during his vacation, and anyone else who got their hands involved!
Some great shots from our unveiling party.
Few Action Shots
Videos of the unveiling and event the following day
Irwindale qualifying lap with wall tap on inner bank
Proof that the car was worth it
